1 - 8 of 8 Posts
Hello everyone, i hope that all of you are safe during the lockdown. I had a small problem with my first generation cts i was driving normally going home and then the alarming sound comes on (3 beeps) and i check the control center nothing is on it when i checked the dashboard the ABS light was on, but the weird thing that if i turn the car off it would go away then after a while it would come back on so i decided to check if my ABS is working and it is but the light keep coming up. Any suggestions of what i should do? May it be solved by a scanner at the mechanic shop?
2005 Base CTS work at Pullen solenoids Glass Factory for 36 and a half years
I would definitely get it scanned. Also check your battery voltage. Should be approximately 13.65 just sitting there and about 14.5 when running.
Roy
2007 CTS 3.6 >131k miles
I assume from your description that only the ABS light is on. If this is true, then you still have brakes but you won't have anti lock brakes if/when you need them. However if the regular brake warning is also on, then your regular brakes have a problem and this may be causing the ABS warning. Either way, as others said, the only solution is to have it checked by a competent person.
Like Roy said have it scanned, an ABS light can be caused by a lot of things so you don’t want to start guessing.
I’m going toget it scanned but the weird thing that today i started the car in the morning to go to work the ABS with the sound came on plus the TC system was off and i was not able to put it on so I guessed it may have something with the throttle?
2005 CTS 3.6L V6
TC is “traction control” and it uses the same system as ABS, a throttle problem would turn on the engine light.
2007 CTS Non-V
Your ABS control module is going bad. Common problem with our 1st gens. There are companies out there who will rebuild your module (you ship it to them) for a fee of course.
1 - 8 of 8 Posts
