1995 Deville 4.9L
Codes:
P039 HISTORY - Torque Coverter Clutch/Viscous Converter Clutch Engagement Problem (I'll get to that later.)
I039 HISTORY - (Loss of Road Sensing Suspension Data - I assume this is from having passive struts, not concerned.)
T027 CURRENT - LF Wheel Speed Sensor Continuity Fault (I've tested the circuit for continuity, checks out.)
T025 HISTORY - LF Wheel Speed Sensor Fault (Replaced hub)
T077 HISTORY - ???
Sometimes the warnings come on as soon as I start, sometimes after driving a bit.
Interesting note: I cleaned the break valve off with engine cleaner and the lights didn't come on for about a day and a half.
I have not yet tried switching relays or cleaning the pump ground.
Anyone know what code T077 is?
Codes:
T077 HISTORY - ???
