I recently eplaced my rear brakes on a 94 cadillac Deville Concours. Once done and driving away my ABS light came on. I pulled the code and it was T033 RR wheel speed sensor Continuity Fault. Does this mean I have a loose wire, or do I need to replace the wheel hub. The repair manual I am looking at says to replace th hub. How hard of a job is it, and is the speed sensor part of the hub. One last thing do you have to use an OEM part. I was reading other post, and the OEM can be 300 plus. If you can hepl I woud appreciate it.
Tom
Tom
