This problem has been resolved. Thank you to all who offered suggestions.
Hi folks,
Need some assistance diagnosing a problem with ABS/TCS on my 94 Concourse. A little background info first. After I replaced my break pads all around and the front and rear right side calipers, the car ran fine. I did notice a slight rubbing noise from the right front rotor but figured I just had to wait for the pad to seat itself. About a week later my right front rotor got smoking hot at highway speed, so hot it was cooking off the grease anywhere near the hub and control arm. Scared the crap out of me, if I had gone any further it probably would have reached flash point. So I limp the car back home and park it. Take a look again to see if I botched any part of the job. Everything seemed good but since the rotor got so hot it warped. I replaced the rotor and put everything back together again. I get ABS and TCS warning now even though everything mechanical seems to be working well. No more rubbing noises etc..
So my question is this; Is it possible I cooked the sensors in the wheel hub assembly? My mechanic ( yeah, I buckled and sent it off) said the ABS module went bad. After reading a couple dozen posts here it seems many ABS problems originate from the right front hub. So I have to make a decision, replace the hub or replace the whole ABS system. I know the standard procedure is to provide the codes with descriptions, but I don't have the car with me to do that. Did a fault in the ABS module cause the rotor to hang or did I cook the hub and now the sensor data is unreliable? Any help much appreciated.
Hi folks,
