:cloud9: My husband bought a 1995 Cadillac Seville SLS. Wonderful car!! I just want to get some of the bugs worked out. The ABS and Anti-lock brake lights are on. Also I get the Traction Disabled message. I checked the PCM override to see if the traction had been overridden manually but it hasn't. The PS24 displays "00". I'm getting the following codes: T073 Current, T027 Current, T025 History, S038 Current, S061 History. Could someone help me and tell me what I need to do?
I have a 1996 Deville Concours, also showing Code T025, which is LEFT FRONT WHEEL SPEED SENSOR fault.
Seems you have to replace the whole hub, but I thought I replaced the sensor only on the other side some years ago. Can you replace the sensor only?
i have exactly the same car and exact same problem. you can clear most of the codes (history) i replaced the left front hub and had the wiring checked and still have the lights appears to be the Elctroni Brake Control Module. which i have replaced yet.
99STS,2004 Jeep Liberty Renegade,98 Deville RIP
Before replacing that EBTCM, check its ground path, a simple solution is to run another ground from the EBTCM to a good ground, then clear your codes. The EBTCM is usually a good reliable unit but when it gets old the ground wire rots out, this might have happened.
Hi guy's I'm a newby to the site and I have a 95 STS with a similar problem. After the car sat for a couple of months in the garage the traction control light and ABS light came on. When I checked the codes it came up with only code T027 LFT FRNT Wheel Speed Sensor continuity fault. Unfortunatley I went ahead and replaced the LFT FRNT hub which made no difference. his ground wire your talking about, wouldn't the codes for all four sensor's be on if there was a bad ground. Just wondering because I can't seem to get rid of it. By the way my car just turned 410,000km with all the original drivetrain, no rebuilts yet.
My understanding is that the LF speed sensor is the first checked. If a problem is detected the fault registers and the others are not checked. I would check the ground to the EBTCM.
