BishopRuger said:
I went on the site today and found some rims that I really like and they offer them in 18" w/255-45-18 performance tires and 20" w/255-35-20 tires. But If 20" rims are not good for the suspension why would GM offer them for the CTS??, and since they are direct from GM, if the 20"rims so happened to cause a problem would the damage to the car caused by the GM rims still be covered under warrenty??
Here's a clip from Pete regarding some of the pitfalls of oversized wheels and suspension changes. It's wordy but some common sense material.
"You just used the operative word;
"impress". Because 20" rim plus sizing is nothing but "impression" disguised by the word "application" on any CTS platform utilizing the exisiting OEM factory suspension geometry and hardware.
At least the "low-riders" have enough common sense to know that a 20" plus size application on a CTS is a "teeny bopper hollywood impression for show and certainly not go". The low-riders also know the difference between putting on a hydraulics show and not trying to build a higher horsepower rated drivetrain platform while "monkeying" around with there suspension geometry without any quantitative engineering modeling to support the effects of what they are doing under those wheel wells!
Like we agree; the premature wear on the tires is the first visual sign of suspension degredation and now there scratching there heads thinking it's purely alignment or tire rotation. :bonkers:
We both know that the factory suspension components are taking an absolute beating and prematurely wearing and CTS owners will be able to line the bottom of their bird cage with the factory 5/50k warranty when they attempt to make a suspension component claim which is inevitable when the vehicle will no longer hold an alignment due to component wear.
For God's sake...it's all written it the 1800 page CTS GM technical manual by the design engineers about the dangers and premature wear to the suspension system by installing this junk!
These CTS 20" wheel/rim upgrades, lowering springs and rear luxury shocks are "backyard garage upgrades" and what is sad is that you have some GM technicians doing the installation???
What the hell kind of Cadillac dealership operates like that when you have a written GM technical manual that says
NO to that "application or modification" and warns of the mechanical and safety dangers???
I just feel sorry for the young folks and the terribly misinformed on this Forum that rely on some of the absolutely wrong upgrades that are disguised as a so-called correct "
application modifications" and then are supported with the statement of;
"well I work for a Cadillac dealer and the GM tech told me......or Jiffy-Lube said; and therfore it's all ok!" :helpless:
It is an absolute fact that playing around with the suspensions ride height without properly engineering the suspension tuning will lead to setback problems with regard to the front and rear wheels where the rear wheels control tracking and the front wheels the vehicles aim or steering and ultimately the proper thrust angle. And as said and "printed"....problems, problems, problems with lead pull wheel alignment, memory steer, undesired wander, drifting and deviation and scrub radius angle which affects camber angle and directional stability.
And installing a camber kit to compensate for the premature tire wear without regard to the premature suspension component hardware problems that are inevitable is like putting a band-aid on a head fracture if folks think that's the answer!" Pietro
