I added a nav unit and I have the other 2 harness... how do I connect the a/v ports? Anyone have the wiring chart for the other 2 harnesses?
Do you have the aux RCA box that's to be mounted in the arm rest with the proper insert?mrproducerdav said:I added a nav unit and I have the other 2 harness... how do I connect the a/v ports? Anyone have the wiring chart for the other 2 harnesses?
There is a chrome trim ring on the bottom of the shift knob. Take a small flat screwdriver and slide it down the shifter.How do you pop the shifter handle?
Correct for all model year Sigma STS.Ludacrisvp said:I don't think you need to pull the shifter handle off when you pull the console out....
Pry down the chrome bezel trim there's an alen key screw.stevenriz said:Oh I was just curious because mines a little loose and I thought I would ask the question since it sounded like his shifter had to come out as well.
