ok after calling the cadillac dealer for a price quote on valve guide seals and finding out they are 1400$ i decided to post here for some help before i make a decision. i am hoping i dont need valve guide seals...i only checked the price because i talked with a friend who is a mechanic and told him about the symptoms with my car which i explain in the post.
so it started a couple months ago when my service engine light came on. i pulled the code and it was a "knock sensor circuitry failure" . i didnt hear a knock and it didnt affect performance. i figured i needed a knock sensor and i would get that done this month for inspection. so i got my oil changed at good year about 6 weeks ago shortly after the knock sensor code was thrown. i told them specifically only to put 7.5 quarts in with the new filter..which was what they had in the computer anyway. so a couple hundred miles after my oil change the MAP sensor started going off. the MAP sensor goes off when i have warmed the car up and driven for a little while. especially when my car is low on gas and its hot outside. it is consuming oil at a very high rate also..about a quart every 350 miles. it was consuming oil at a quart every 800 miles before the oil change.
since the map sensor has been going off i have a few other codes getting thrown aswell. they are in history and dont show any signs while i am driving. i believe they are all connected to the MAP sensor being thrown. the car is at the shop right now getting looked over for everything i will need for inspection. if it will be this much just for the MAP sensor problem i may have to retire her to the junkyard
the serpentine belt went when i was driving to the shop yesterday also haha...
any help is very much appreciated...thanks
