1 - 10 of 10 Posts
none
I’m currently offshore looking at an add on auto trader for a vehicle for the wife. I came across a 08 CTS that I am interested in. Couple problems though that I don’t quite understand. The VIN is 1G6DV57V180212048. The dealer emailed me saying this was a base model W/1SB. I’m not an expert and that’s why I am asking here, but didn’t the 1SB only have the PFI engine?
The listing also says the car has a Bose system. On my Z06 that is equipped with a Bose system, there are plenty badges in the car that say Bose, shouldn’t the Caddy have the same? Also on the radio, it is not listed as a NAV model, but the screen shot of the head unit shows a satellite subscription page on the traffic tab, but also has a full map tab. Does that mean it actually does have NAV?
The listing also has something that kind of got me off guard. It says sunroof Delete. There is a very clear picture of a double sized sun roof in the picture taken from the interior that you can see thru like a normal sun roof. It does not appear to be a delete panel. Anyone have any opinion on what they are talking about there?
2009 CTS 3.6 LY7
...it just seems like the 'list' and the 'pictures' don't match. The only 'Bose' logos I see on my '09 are at the front door speakers. My no-NAV doesn't have a pop-up screen. If the 'picture' shows a sunroof the 'list' should not show 'sunroof delete'.
08 CTS DI AWD Luxury-Performance II ThunderGray/Titanium
have you contacted the seller to clarify the details?
none
waiting for them to open. but wanted to have my ducks in a row befor i contacted them. I know ill be talking to a salesman, not a mechanic, so I wanted to have enogh info to tell if i was getting led on.
well I called. the ladie that answered wasnt much help. I did find this, https://service.gm.com/dealerworld/vincards/pdf/vincard08 06-01-09 r1.1.pdf
witch leads me to belive that the car is in fact suposed to have nav at least, and is a DI modle. I wonder if i can get them to send me a picture of the service parts lable.
'08 CTS Black Raven/Ebony 3.6DI FE2 6-speed manual
Here's an old thread that may help explain codes for you more - http://www.cadillacforums.com/forum...ssion/130777-rpo-codes-2008-cadillac-cts.html
Given the description and the pictures may not watch I'd suggest being careful - at least ask for a picture of the RPO codes which is on a sticker on the back side of the spare tire cover to confirm what you should be seeing for that particular car...
Update with a couple of more links used in the past...
Basic RPO code overview
http://www.caddyinfo.com/2008ctsrpocodes.html
Great FAQ compilation with more package / RPO code details about 1/2 way down...
http://www.cadillacforums.com/forum...ral-discussion/223306-cts-faq-diy-thread.html
Also, the sticker on the driver's side door will have the build date - not all 2008s have Bluetooth integrated depending on whether its part of an option package, that was introduced with May/08 builds if I remember correctly. The quick way to check if someone has access to the vehicle is to press the steering wheel mounted button for voice and say 'bluetooth' - if Bluetooth is available then a list of menu options will be provided...
none
Thanks for the replys. The guy did email me a picture of the RPO code lable, and i ran it thru http://www.cadillacfaq.com/rpo/.
I am satisfied that this car is equiped nicely according to the codes and vin. I will also have a look over the links you poseted, thanks again!!
2009 CTS4 Premium & 2012 SRX4 Luxury
I've seen many listings on Autotrader and Cars.com that show the "base" feature set, including sunroof-delete, when the car is obviously optioned otherwise.
2008 CTS4 3.6 LY7
No matter what the second gen CTS 2008-2013 com standard with a Bose stereo. The difference in the stereo are 8 or 10 speakers. Nav or non nav.
2014 CTS Coupe 3.6 RWD Perfomance Pkg, TriCoat White Diamond
and 14's...
1 - 10 of 10 Posts
