Anyone else experiencing similar problems:
- I seem to have to adjust the temperature all the time (it's either too hot or too cold).
- There seems to be a significant difference in noise level between the fan in the OFF position versus the fan in the first notch up (i.e. - the lowest setting). It isn't quite so noticeable when driving, but if you're parked, and you switch between those two settings, it's pretty noisy.
- The lowest fan setting seems to blow too much air all the time. I'm constantly turning the fan off (even though there is still a small amount of air coming out probably for circulation purposes).
