My 2004 V8 AWD has a rumble/vibration at idle with the air conditioning on. Turning off the A/C or raising engine speed eliminates the vibration. It feels/sounds like being next to a car with one of those annoying, booming bass systems. Anyone else encountered/corrected this?
My 2007 SRX has the same problem. I dont think GM puts much thought into engine idling smoothness. I would perfer not to feel the motor idle at all but it seems that in all the recent GM's i have driven this is a problem. I had a 2000 Chev Cavlier that you thought had stalled at stop lights because it was so dam smooth and quite !
2005 SRX
Something is probably mechanically loose. GM puts tons of effort into getting a smooth idle in both the PCM program code and mechanically.
Take her in.
2004 srx V-8 awd
Toyota's 6 cylinders have the smoothest idle that I've experienced. Can't even tell they're running unless you check the tach.
