1 - 20 of 25 Posts
1996 El Dorado
on a el do can u use the do it ur self a/c fill kit to recharge the air??? cuz i was wondering before i went out and got some...
2008 SRX
No offense, but please, this isn't your cellphone text messaging. All of the letters are easily accessible on the keyboard. Go ahead and practice.
Yes you can use a recharge kit from your local parts house. You don't get the pleasure of evacuating the system, but you can add R-134a and get a kit with the gauge included so you can monitor the low side pressure.
1996 El Dorado
sorry... didnt mean to was in a rush.... new to this whole forum thing... ok another question than when i click on a/c on my car.. it was says compressor off so how would i enable it back on?
1996 El Dorado
Discussion Starter · #9 ·
yes and i went to the tech area and i tryed to clear the codes with what it said and stuff but nothign ever poped up...
1996 El Dorado
Discussion Starter · #10 ·
so i am doing something wrong in order for nothing to pop up or is there somthing wrong with my cars computer?
take the negative battery cable loose for 10 seconds, the computer will forget the low freon code, open the valve on the can of freon on low side, then start engine, be sure to get freon with oil already mixed with it or use a couple of oil charge cans before you put the freon in you lost the oil when the freon leaked out.
2010 DTS
Whoa. A "couple of oil charge cans"? You're going to put way too much oil in there. Don't add any oil unless you drained some replacing a component or had a sudden catostrophic discharge.
1996 El Dorado
Discussion Starter · #14 ·
i am holding the buttons on the ccc the off button and than the off button with the pass above it how long do i hold them togather for i did it for leik 3 mins nothing came up.. well my system been torn apart when i pulled the motor out for the headgasket repair...
1996 El Dorado
Discussion Starter · #17 ·
ok i figured what i was doing wrong... and these codes came up ac 1347, tc 0061 tc 0073,pz 1970 pz 2042, and rf 2560
1996 El Dorado
Discussion Starter · #19 ·
sorry if this seems really stuipd.. but i dont no how to clear the codes i mean it goes to clear codes.. but than what do i do i hit off but nothing happens..
1 - 20 of 25 Posts
