Well when i went to disconnect the hose the retrofit valve started spraying so I'll have to replace that quick now.
Im out of low side ports. Off to WalMart.
For some strange reason I had extra high side adapters from other retrofit kits but no lows. I have to get a new hose that fits it right anyway. The straight connect goes on but not too well so Im going to hopefully find a hose that has a brass 90 degree disconnect instead of the cheap plastic ones.45psi is gonna be about 49-50°F with 134.
And out of low side ports? Do car A/C systems have some funky shit with how you hook up a manifold that I don't know about?
