1 - 8 of 8 Posts
02 deville a/c only blows out of floor and defroster vents at the same time.It will not blow out of the dash vents.What could the problem be and how hard would it be to fix.Thanks,Guy.
Most times with that problem, its a vacuum leak under hood. If no vacuum reaches the programmer, it defaults to defrost mode to keep the winshield from fogging up if its winter.
2005 Cadillac DeVille DTS
No vacuum control on these vehicles... HVAC actuators are all electronic.
Start with Ranger's advice - always good.
Joe
2003 Deville Base
What is DTC's I have same problem
what car do you have? see the sticky at the top of this page on how to pull codes. If it's 1996 or later, the codes will read out as a letter followed by four numbers. Refer to the definition list. When you post codes always include the definitions along with whether the code is Current or History.
we NEED more SPECIFIC information -
start with the year - make - model of the car -
THEN a detailed description of your SPECIFIC problem -
1 - 8 of 8 Posts
