1 - 8 of 8 Posts
98 deville
Hi Everybody Just Bought a 98 Deville with a few problems
Do I Really Have to Remove The Door panel to Install a new side mirror ?
Also The AC I Can Hear The Compressor clutch On and Off But I'm Not Getting any air Thu The Vents
Any Help Will Be Appreciated Thank u
98 Deville 124 Miles
Read and study the sticky post ^^^ "how to pull codes". Practice, then write down any codes found, whether they are Current or history.........come back to the sticky and open the link with "obd2" in the URL to get to a Master Index of links to any P,B,C, or U codes. Write it all down and come back and post here.
You may find a trouble code for one of the HVAC blend/diverter door actuators.
2010 DTS
Do you get any air flow when in heat or vent mode? Do you hear the blower running?
Yes, you have to pull the door panel to replace the mirror unless it's only the glass you are replacing.
98 deville
Discussion Starter · #4 ·
Thank u Guys No I Don't Hear the Blower Running
And I'm Not Getting any air When in Heat Or A/C Thank u Again
2010 DTS
Sounds like you are in for a blower motor replacement. There is a "how to" tutorial in the Tech Tips section.
P.S. No one has the codes memorized. Always post the code definitions along with the codes.
98 deville
Discussion Starter · #7 ·
Hi Guys Heres What i Find
PCM P0603 Control Module Long Term Memory Reset
PCM P0463 Fuel level Sensor circuit High voltage
IPC B1552 Keep alive memory (kam) error
IPC B2711 Passkey open/shorted after good key
ACM B1341 Air mix door two movement falt
SDM B1827 I Could t find the code i look all over and no luck
Im New In Cadillac s so Pls help me out I don't know what to do Next Thank u So Much ....
2010 DTS
The B1341 will affect the temperature control (I think that might be the passengers side, but not positive), but that is irrelevant at this point because the blower is not working.
1 - 8 of 8 Posts
