hey whats up guys, i'm new here and i just got a 95 fleetwood brougham about 3 months ago. talk about headaches trying to install a sound system for it.
anyways now i'm having a few problems, i just found out my A/C Clutch is going to go out on the compressor. i was told that i can disconnect the power line for the A/C compressor and it should free spin. this would stop it from locking up once it goes bad. is this true? i would i be able to drive it like that all winter long untill i take it in, or at least untill the holidays are over?
i couldnt find the power line on it, anyone know where i can find it or discontect it?
also anyone know where i might be able to find the fuel filter? can seem to locate it, would i have to drop the tank on this one?
thanks
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
The fuel filter is located along the frame rail under the rear passenger door.
Very easy to R+R.
Sorry, I can't help with your A/C problem.
Post back your solution.
1994 Cadillac Fleetwood Brougham (some show and some go!)
Not sure that disconnecting power on the AC compressor will solve your problems, but there is indeed a plug harness on the compressor. If memory serves, it's best to get at it from under the car. Located in the rear of the compressor I think???? Good luck.
Oh yeah, ditto on the fuel filter location. Just inside frame rail, driver's side, near rear door area.
