Hello,
Didn't read this forum first and when I removed the radiator from my 2001 Seville STS I fully removed the a/c condenser. Can anyone tell me the steps to evac the system?
Thanks in advance.
Kenny
connect an AC manifold set to the HIGH PRESSURE and LOW PRESSURE ports of the AC system -
connect a vacuum pump to the yellow hose of manifold set -
turn on the vacuum pump -
open BOTH the HIGH and LOW side valves -
and let the vacuum pump run for at least one hour -
the longer - the better - you will get close to 30"/Hg
close BOTH the HIGH and LOW side valves - turn off the vacuum pump -
let the system set for at least 15 minutes -
the system should maintain the vacuum -
if it does - you are ready to recharge it -
if the vacuum bleeds off -
there is a leak that must be found and fixed -
that's how to properly evacuate the system -
with that said - technically - anytime the system is exposed to air -
you should replace the receiver/dryer - the desiccant material quickly absorbs moisture -
