Site News and Registration problems is not the answer. Let's move this to the proper Deville forum. Please read the descriptive text in each forum title banner.
Metal pieces/dust is terminal. Compressor shot, entire system needs serious cleaning, expansion orifice replacement. Complete overhaul and oil/refrigerant recharge.
2001 Cadillac DeVille DTS
Metal pieces in the a/c condenser is an indication of a bad compressor, which some people refer to as "black death". This is a contamination that is from excessive wear of the inner mechanical parts of the compressor, such as the bearing surfaces. You will need to have your entire a/c system flushed thoroughly, after replacing both the compressor and the expansion orifice tube.
2010 DTS
You'll also need to replace the accumulator and the condenser.
It's gonna be an expensive repair, but cheap out and you'll probably be replacing the compressor again.
and add a new ACDelco 15-1747 in-line filter somewhere in the low side hose-
