After fixing the fast idle issue, I proceeded to the lack of air conditioning. After measuring low side pressure (65#) and clearing BCM codes, the compressor clutch won't engage. Disconnect the battery; no engagement. WTF. I've always been able to clear body codes to get the compressor to kick In long enough to get some Freon in and keep things rolling. Not this time.
What can I do next? Can I jumper one of the pressure/temp sensors?
Temp set at 60°, but the HVAC kicks it out to ECON after a few minutes.
Re: A/C compressor won't engauge-'89 eldo
that is obviously static pressure -
and yes - the pressure is too low to operate the compressor -
what codes?
low pressure is one thing -
a failed pressure switch is another -
try this -
engine off -
have the AC gauges connected -
have the full can of freon connected -
valve on the freon can open -
low-side service valve on the gauges open -
turn ignition on -
turn AC on -
set AC temp to 60* -
clear the codes -
start the engine -
the compressor should engage and draw the can of freon in -
when the can of freon is empty -
close the low-side service port -
the compressor will probably start cycling -
add more freon until the proper pressures are reached -
sometimes -
the low pressure switch is so sensitive
that it just won't allow the compressor to engage -
if this happens - you can unplug the switch -
and put a jumper across the plug to force it -
but - be very mindful of the low pressure -
Turns out, my gage set let me down. I jumpered the low press switch and the compressor came on, but the gage said 60#, didn't move. Jug of 12 Is hooked up but the valve on the gage set was closed. Removing the fitting from the accumulator, I noticed the center pin In the low side hose that Is supposed to press In on the pin In the accumulator Schreater (?)valve, was missing! Apparently the 60# I was reading was from the drum pressure that must of been present at hookup.
Swapping gage sets, I now read 5# Freon. Injecting some Freon, the compressor starts pumping, but it just doesn't sound right. I know that sound; it's a failing compressor. Time for a new one; this one's original.
that ALWAYS happened when removing the service hose - :rant2:
NAPA sells/sold a plastic bag
with 5 brass core depressors and 5 rubber inserts
for a few bucks -
