1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
My A/C clutch is making awful noises and leaving bits of metal shavings everywhere. I've only ever tried to remove a clutch from a compressor one other time in the past and it ended poorly (broke both the compressor and clutch by using a puller inappropriately).
The clutch assembly is $93; the compressor WITH the clutch assembly is $195. If it's possible to replace the clutch with the compressor installed, I think that's the way to go. Even if I can remove the compressor without discharging the lines and replace the clutch, that would be ideal too. It's a pain in the butt, and costly, to evacuate the system and recharge it.
So what would you do? Just the clutch or the whole thing?
