Well, had a pretty scare today doing a little routine maintenance on the 90. I replaced the EGR valve as well as vacuum hoses, and seafoamed the EGR passages. I had to disconnect the MAP sensor vacuum hose and unbolt the fuel line for the passenger-side fuel injector. Unfortunately, I was very busy this morning and only had 40 minutes to do the job, test-drive it and make it to lunch before my class. Replacing the EGR valve and vacuum hoses went just fine. Started it up, and it ran like sh*t until the seafoam did her magic. Still running a little rough, and the SES light was on. Checked it, code 33.
I thought 33 was an EGR valve problem, so I'm staring at the thing, making sure everything is tight and connected. I can't figure it out, so I take it for a test-drive, and it runs great! A slight hesitation at about 10% throttle, but great otherwise. However, I'm going through gas like dollar night at a whore house, and get another code, 45. This one I know is a rich O2 sensor.
I get back into my apartment's parking lot and open the hood, can't see a damned thing wrong. I'm still thinking that 33 is an EGR problem. I shut it off, went inside and opened the service manual, when I realized that 33 was a MAP sensor problem. I went out and immediately noticed I forgot to reconnect the MAP sensor vacuum hose! No wonder I was getting a code! Of course, here's where it got fun. I also noticed the passenger-side fuel injector line was disconnected. It was up against the side of the throttle body, just pumping fuel out at 11 psi the whole test-drive and parking lot idle, a good 10 minutes!
I didn't think anything of the enormous puddle that formed as soon as I started the car, because I spilled so much Seafoam on the engine trying to get it down into the EGR passages, I just figured it was Seafoam hitting the ground. Well, I guess that explains how I went from 3/4th of a tank of gas down to 1/4th in less than 10 minutes......
The thing I can't figure out for the life of me is how it ran so well with only 1 injector getting fuel. I mean, it ran damn well! But, problem fixed. MAP sensor reconnected, fuel line re-attached, and only a half-tank of gas on the ground, lol! My story.
