1 - 10 of 10 Posts
Hi there fellas,
anyone know the proper wattage for replacement fog light bulbs for a
99 Seville STS? I want to get the factory required wattage bulb. Thanks
-Mike
1999 Seville STS Northstar 32 Valve V8
1999 STS fog light
How do you take off the fog light to change the bulbs??? i have a 99 STS and only one of my fog lights works. I need to fix it ASAP.
Fog light bulbs for ’99 STS are 880 (50W). You need to unclip a portion of the splash shield in order to access the back of the fog light assembly from underneath.
Re: 99 STS fog light
How hard is it to take off the splash panel? Would I need to jack the car up, or could I just slide underneath it?
2005 Deville Limited Edition
You might need to jack the car up at the front for room to move about, I had to do this early summer. It's easy to do, just remove the plastic push clips (the center of the clip pulls out). I had to remove over half the clips to allow room to get my hand in to remove / replace the bulb.
The bulb cost is about $9 - $15 bucks depending on brand and it's an 880 rated at 50W.
1 - 10 of 10 Posts
