I have a 1999 sts that has NOT been a problem for years and now all of the sudden is discharging the battery, I tried disconnecting the power at the fwd fuse block and the alt power wire. the abttery still runs down. this means the power drain is connected thru the fuse panel under the rear seat, when the neg battery cable is removed/reattached i hear relays closing, removing the one that was closing makes others close and so on .... difficult to pinpoint to just one relay. also, the amp for the radio is energized, the sub "pops" when neg battery cable is "brushed" against the battery terminal ...is it possible the switch on the transmission (actual ignition switch) is a problem and some of the assy's are stilll powered up. does it make a difference how the relays are oriented in the fuse block - I havent located a schematic to prove-disprove orientation
