say i need some help fig u guys could save me some money before i take the car and my girls car to get fixed
i drive a 1999 seville sts and these are the following codes that i got off the system
pcm p1611 Current
pcm p1652 Current
ABS C1252 current
ABS c1253 Current
ABS u1255 Current
Amp U1604 History
DIM B1324 History
IPC B1652 History
IPC B1983 History
IPC U1300 History
RIM B0532 History
SDM B1327 History
any help will be much appreciated.
No that didint help i mean i know one of them is for my left joint going out and one of them is abouyt the service stability system but i dont know what the other ones are. anyone know where i can look up all the codes
99 STS
pcm p1611 Current
pcm p1652 Current
ABS C1252 current
ABS c1253 Current
ABS u1255 Current
Amp U1604 History
DIM B1324 History
IPC B1652 History
IPC B1983 History
IPC U1300 History
RIM B0532 History
SDM B1327 History
B1982 - Device Power Circuit High
B1983 - Device Power Circuit Low
Because of these two, I say test your battery and connections, and charging system and grounds. Maker sure they are 100% a low battery can cause this too. Clear codes and see what returns.
If you have the orginal battery, then I would say it's time for a new one.
