can't get the parking brake to release even when switching to drive. Have to manually release each time. Easyfix?
Cadillac ETC 1994
Hi, I'll try to explain the same thing with my car.
after replacing heater core I'd get the same problem coz they removed half of the cabin inside. they simply forgot to put down vacuum hoses
under a gear lever.after all was done properly they recommended to replace that unit asap. you've got some bad vacuum connections somewhere
'98 STS (RIP @ 206,xxx miles)
Under the rear seat, two park brake relays(A and B). Remove and reinsert them to wipe the external contacts clean.
Unlike your car, the '99 uses an electronic solenoid release.
