Sory, STS. :yup:STS 310 said:Dang, GAMER, sometimes I have to read your posts a couple of times to get the full jist of what your saying. All good though!!
People say change it a 30,000 because most ATF last 100,000 miles only at 170 degrees F and for every 20 below that and 10 degrees above 170 ATF last only have that. Most any car will not have a transmission cooler (that’s part of the reason why some people in racing will run a cooler line) and it runs at engine temperature which is around 195 degrees so that would make it approximately a 30,000 service. This is why towing will cause the ATF to break down faster and is recommended to change it at shorter intervals because the transmission components heat up the ATF.If the counter doesn't move after you put 100,000 on the car, just change the filter and fluid and be done with it. Since I never buy new, I change it when I get the car to be on the safe side. After all, what is the life of a car? I've seen 'em with over 100,000 on the clock and they're like new and I've also seen them with 30,000 and they look like they were used in the Battle of the Bulge.
My 94 V6 Dodge Spirit had one..............................Most any car will not have a transmission cooler (that’s part of the reason why some people in racing will run a cooler line)...........................
Yea, and I was the last poster before this thread went to sleep. I'll be going on 116,000 miles on my Seville and the counter is still at 100%.Holly cow I didnt see that.
And to think that just 7 more days and it will be officially 2 years since it ended.
Gotta get some Lotto ticks with these #s lol
If you still have diagnostics built in, you may find it in there. The '98+ Seville has a different cluster that has information that scrolls up or down. It's in there.I can pull up the oil life left percentage . but haven't seen any thing on the transmission, how do you do that? '98 Eldorado ESC. Thanks.
My 02 SLS had 128,760 mi on it when I bought it recently, tranny life 99%.Yea, and I was the last poster before this thread went to sleep. I'll be going on 116,000 miles on my Seville and the counter is still at 100%.
When I bought my 02 SLS it had 128000 on it and the life was at 99%. Supposedly it had just had a flush.We SLS owners engage in spirited driving, too. I think that the parameters changed between earlier and later Caddys. That's why the reading doesn't move. You probably have to set the trans on fire to get the reading to change.
Might it overheat due to a failed water pump/blown head gasket? If the radiator core temperature rose to high, that might interfere with transmission oil cooling.The percentage won't change unless you overheat it.
