'98 ETC Black 90k miles
Did you check for actual codes in the system, or are you waiting for the DIC to flash a problem on your dashboard? If you haven't checked for actual codes, read the sticky at the top of the page and find out how to pull the codes from the vehicle computer. Bring a pad of paper and a pen when you go to check them, and then post the codes here or look them up. Try searching for 'pull codes' or the service codes themselves if you get stuck.
In case you're not sure where to look to pull your codes, click here.
