'99 eldo blk on blk, '13 ATS,'13 SRX premium
Hello Everyone,
I was taking a 100 mile highway clean out drive,
. I was doing about 75 with cruise on then went WOT and downshifted(ye ha)
went as fast as I felt lucky at, slowed by brake and tried to set cruise again,
NO worky, checked cruise fuse and it was still good. Is there another fuse somewhere? Speedo still works, could the cable from the CC to tranny be
broke. If its not showing at least 25mph CC wont come anyway.
thanks Ed
by the way N*s rule
Check the switch at the top of the brake pedal arm. If it's out of adjustment, cruise will NOT work - the slightest touch of the brake pedal drops out cruise. Supposed to be "self-adjusting" in its clip holder - but pop it out and mess with it anyway.
It's a start ..........
Thanks Sub,
I "messed with it" like you suggested and its working now. The wiring was a little stiff
so I just pressed the pins in tighter and I think I might have helped the self adjuster
a smidgen. Perhaps I moved the air around it when I changed the hazard flasher the day
before and road turbulence moved it. btw the flasher was good, the switch had to be
forced in!(one thumb and other hand). I've been going to call Rippy and ask Chris about
a turn signal canceller , maybe I should check on a hazard switch also...
Hey Sub, thanks for the tip.
She got 28.5 mpg on that road trip! Avg 58.5 mph, mostly faster,yee haw
thanks again Ed
Chris is no longer with Rippy Cadillac and they have stopped shipping to CF members.
If you're into dealerships, try Lindsay Cadillac in Alexandria, VA. Or, look through either www.gmpartsgiant.com (insane high shipping prices) or www.nalleygmc.com
thanks I was really hoping for a part number, they are so specific (tilt,cruise, etc) . thanks for
help.... Ed
