I would say nothing over 1000 lbs. but I would not tow anything with this car. You have to run wires for lights which causes nothing but electrical headaches. Also it is FWD so it will not handle much worse than if you were towing the same trailer with a RWD car. It also puts A LOT of extra strain on the transmission which was designed only to pull the weight of the car and these transmissions don't even fare well under just that amount of weight.
