1 - 20 of 30 Posts
1999 cadillac deville
Was driving home from work today and a service charging system. Warning came on my dash... i then watched as my colts droped .1 at a time then stalled out on the couch side of the road which is where a am now. What all should i be checking besides the altanator?... i REALLY am beginning to hate this car
Well the other possibilities are the cables, terminals, and battery. But that sounds like a bad alternator.
Depends what you pay for the part, and what the shop charges to put it in. Pretty large price range.
Depends where you live. A good shop here, ~$80/hr. ~$110/hr at a dealer.
so about 700 to 900 if the hours i foubnd to do it are right.... right well junkyard it is....
1998 Cadillac Deville
I watched plenty YouTube videos on changing alternator in our Devilles... One guy actually did it without removing the Radiator. Not recommended tho.
http://www.youtube.com/watch?v=an3rl8H0y0o (alternator out the bottom) Not recommended tho.
If i understood how to do it... U can do this yourself... Will take roughly an hour or two or 3.
Buy an alternator like Basscatt said and spend some quality time with your Deville. :D
Sorry for the multiple post but jus incase u want to try to do it yourself before considering the junk yard, ive posted the DIY instructions below...
GOOD LUCK
Generator Replacement
Removal Procedure
Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable.
2. Remove the accessory drive belt. Refer to Drive Belt Replacement .
3. Remove the upper front bolt.
4. Remove the radiator. Refer to Radiator Replacement in Engine Cooling. TWO POST DOWN
5. Raise and suitably support the vehicle.
6. Remove the front engine splash shield.
7. Loosen the rear generator bracket from the engine.
8. Remove the top bolt.
9. Remove the front lower mounting bolt.
10. Remove the lower rear mounting bolt.
11. Remove the upper rear mounting bolt.
12. Remove the duct from the back of the generator.
13. Disconnect the following electrical connections:
• Regulator
• Battery output
• Heated windshield (if equipped).
14. Remove the front generator/ A/C bracket.
15. Rotate the generator and remove.
Installation Procedure
Install the generator.
1. Install the front generator/ A/C bracket.
Notice: Refer to Fastener Notice in the Preface section.
2. Connect the following electrical connections:
3. Install the duct to the back of the generator. Align the duct to the generator black duct.
• Regulator
• Battery output
Tighten
Tighten the battery output cable to 20 N•m (15 lb ft).
4. Install the upper rear mounting bolt.
Tighten
Tighten the upper rear mounting bolt to 47 N•m (35 lb ft).
5. Install the lower rear mounting bolt.
Tighten
Tighten the lower rear mounting bolt to 47 N•m (35 lb ft).
6. Install the front mounting bolt.
Tighten
Tighten the front mounting bolt to 47 N•m (35 lb ft).
7. Install the rear generator bracket bolt to the engine.
Tighten
Tighten the bracket mounting bolt to 47 N•m (35 lb ft).
8. Install the upper front bolt.
9. Install the radiator. Refer to Radiator Replacement in Engine Cooling.
10. Install the front engine splash shield.
11. Lower the vehicle.
12. Tighten the upper front bolt.
Tighten
Tighten the upper front bolt to 47 N•m (35 lb ft).
13. Install the accessory drive belt. Refer to Drive Belt Replacement .
14. Connect the negative battery cable.
Tighten
Tighten the negative battery cable bolt to 15 N•m (11 lb ft).
© 2013 General Motors Corporation. All rights reserved.
2002 DTS, 70 Cougar conv, 2020 XT4
One source says standard labor hours for this job = 2.4, not counting any diagnostic time to first conclude it is a bad alternator.
Engine Coolant Fan Replacement
Removal Procedure
Remove the hood latch bracket. Refer to Hood Primary Latch Replacement in Body Front End.
1. Drain the engine coolant. Refer to Cooling System Draining and Filling
2. Remove the headlamps. Refer to Headlamp Replacement .
3. Remove the condenser mounting bolts.
4. Remove the radiator brackets.
5. Disconnect the upper engine oil cooler hose from the radiator.
6. Remove the air cleaner. Refer to Air Cleaner Assembly Replacement
7. Disconnect the lower radiator hose from the radiator.
8. Tilt the radiator forward.
9. Disconnect the electrical connectors from the cooling fans.
10. Disconnect the generator inlet cooler hose from the radiator.
11. Remove the cooling fan assembly from the radiator.
12. Remove the radiator.
13. Remove the fan retaining nut (5) from the motors (2).
14. Remove the fan (4) from the motor shaft
15. Remove the motor retaining screws (3).
16. Remove the motor (2) from the shroud (1).
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
1. Install the motor (2) to the shroud (1).
2. Install the motor retaining screws (3).
Tighten
Tighten the fan motor mounting screws to 6 N•m(53 lb in).
3. Install the fan (4) to the motor shaft
4. Install the fan retaining nut (5) to the motors (2).
Tighten
Tighten the fan retaining nut to 6 N•m (53 lb in).
5. Install the cooling fan assembly to the radiator.
6. Install the radiator to vehicle.
7. Connect the generator inlet cooler line to the radiator.
8. Connect the electrical connectors to the cooling fans.
9. Connect the lower radiator hose to the engine.
10. Install the air cleaner. Refer to Air Cleaner Assembly Replacement
11. Connect the upper engine oil cooler hose to the radiator.
12. Install the radiator brackets.
13. Install the condenser mounting bolts.
Tighten
Tighten the condenser mounting bolts to 13 N•m (10 lb ft).
14. Install the hood latch bracket. Refer to Hood Primary Latch Replacement
15. Install the headlamps. Refer to Headlamp Replacement .
16. Fill the cooling system. Refer to Cooling System Draining and Filling .
Removal Procedure
1. Drain the coolant. Refer to Cooling System Draining and Filling .
2. Disable the SIR. Refer to Disabling the SIR System in SIR.
3. Move the forwarding discriminating sensor out of the way. Refer to Inflatable Restraint Front End Discriminating Sensor Replacement in SIR.
4. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement
in Body Front End.
5. Remove the cooling fans. Refer to Engine Cooling Fan Replacement .
6. Disconnect the radiator inlet hose from the radiator.
7. Disconnect the radiator outlet hose from the radiator.
8. Disconnect the engine oil cooler lines from the right radiator end tank.
9. Disconnect the transmission oil cooler lines from the left radiator end tank.
10. Remove the left and the right engine torque struts.
11. Remove the upper radiator support screws.
12. Remove the radiator from the vehicle. Lift the radiator up and out.
1. Install the radiator to the vehicle.
2. Install the upper radiator support screws.
Tighten
Tighten the bolts to 6 N•m (53 lb in).
3. Install the transmission oil cooler lines to the radiator.
Tighten
Tighten the transmission oil cooler line fittings to 27 N•m (20 lb ft).
4. Connect the engine oil cooler lines to the radiator.
Tighten
Tighten the engine oil cooler lines to 18 N•m (13 lb ft).
5. Install the left and the right engine support torque struts.
6. Connect the radiator outlet hose to the radiator.
7. Connect the radiator inlet hose to the radiator.
8. Install the cooling fans. Refer to Engine Cooling Fan Replacement .
9. Install the air cleaner assembly. Refer to Air Cleaner Assembly Replacement in Body Front End.
10. Install the forward discriminating sensor. Refer to Inflatable Restraint Front End Discriminating Sensor Replacement in SIR.
11. Enable the SIR. Refer to Enabling the SIR System in SIR.
12. Refill the coolant. Refer to Cooling System Draining and Filling .
Discussion Starter #12
Right... so i would try to do it myself.... but i have no damn idea how to do what you just said or where 3/4 of that stuff you mentioned is on my car
Well at one point I didn't either but I'm learning as I go
Only thing I could suggest is find a mechanic that will Work With U -- Not Jus For U -- and will work with u for a reasonable wage
I would have posted pics and images but the CF won't accept the ones I have bc of their size
I've learned a lot from CF members but Google, YouTube and my Mechanic friend have been my best sources on understanding the Nortorious Northstar. :D
At least u can use the instructions I posted as a step by step reference. They're from the Service Manual.
Discussion Starter #14
Steps 1 through 4 in the radiator out.. where can i find more into on those steps?
All the steps are there
U jus have to understand what ur lookn at
The objective is to remove the radiator
To do that u must remove the fans 1st
Unhook ur 2 motor mounts, then top radiator hose
Get back to me when u did that
This is why posting long, complicated procedures from the FSM is a waste of time in most cases.
All the steps are NOT there. That's why after most steps it says "Refer to xxxxx". You have to skip around the FSM.
mhswres1, if you're going to do this yourself, you're going to need a Helm FSM for your year and model. You can find them on Ebay.
Discussion Starter #17
I know this is asking alot.... but if someone can give me a list in order a little more organized and descriptive in some places.... i think im going to attempt to do this myself
Discussion Starter #19
What size pulley do i need said theres 2 sizes. 57mm and 63mm. Car os a 99 deville elegance
1 - 20 of 30 Posts
