Mac and Betty silver and pearl 99 devilles
99 deville rear window trim pops up on both sides. I removed and noticed that the plastic was worped is this normal and does any one have a idea how to fix or do i need new ones?
any idea which blend door actuator acmb1341 is top or bottom i replaced both and now i get a current code
1999 Cadillac Deville
Almost All plastics can be rewarped, the hard part is to get the plastic in the position you want it. You almost have to clamp it or fasten it somehow and then very carefully heat it with a heat gun. Some things are so bent out of shape you might have to do it in small steps. You have to be careful to not heat it too much or you will destroy it.
NOTE - this thread died 7+YEARS ago
