Hi, I'm back for some advice. My 99 Deville has a bad bushing at the top of the driver side rear wheel knuckle. Can someone tell me if the bushing can be replaced or do I have to replace the entire wheel knuckle?
thanks
· 2007 DTS
2007 DTS, 1991 Eldorado(retired), 1999 Deville (retired)
The whole knuckle is the only way. Be prepared to replace the wheel bearing also unless you have a good way to seperate the bearing from the knuckle without destroying it and the dust shield. Someone here should have more advice for you!
'99 DeVille, K&N intake, MSD ign w/8.5mm wires, custom exhst
Yes it's true that you have to replace the WHOLE knuckle, but the spindle bearing thing; horse hockey, I've got the EXACT SAME PROBLEM & I got one from boneyard(not always advisable). Life is like a bone yard; ya' never know...:hmm:
thanks
HERE IS THE ANSWER MY FRIEND !!
MARCH MADNESS SALE
GET THEM NOW FOR $199.00 & SHIPPING
Last Shot Auto Parts, LLC We are the LEADER in REPLACEMENT Cadillac Rear Knuckle Bushings for your car !!
They fit All Models from 1993 to 1999, and Eldorado to 2002. The Suggested Retail Price for these Cadillac Suspension Bushings is $249.00 & Shipping,and provides both Cadillac UPPER Bushings and Cadillac Lower Bushings in the Set, requiring only 1 set per Vehicle. The Bushings will enhance the ride and control and will return the car back to the Quiet, and Smooth Original Ride.
The Bushings carry a 1 Yr Limited Warranty and are Real Automotive Quality Products, Designed & Engineered Specifically to remove design failure and flaws inherent in the GM parts, and exceed the OE performance requirements for your Car !! We sell Worldwide, and provide Installation Support necessary for a Super easy Install with Instructions that are included.
You Won't Damage The Bushing Or spindle Installing these Cadillac Bushings! We Quality check the OD on our bushings and refinish the surface to closely held tolerances to insure ease of insertion, while providing a STRONG, reliable, and safe product!!
(Also we can Part Number the Product as well, as we sell more than just this part and application !!! )
For the do it yourselfer or the pro with minimal tools. We have your bushings in stock !!
Beware of Molded Plastic (Polyurethane): It squeaks going down the road ! DON'T BE MISLED !! They OFFER installation on your knuckles because certified Mechanics WON'T install them ?!! And they GREASE them so they won't squeak AT FIRST for a short while!! When the lube is gone listen to the wonderful Squeaky Cadillac !!?!! And then you can end up with this issue:
"I have a 1997 deville d'elegance. I repaired the rear knuckles......................... and used POLYURETHANE performance
bushings for the top. However after ~2500 miles, I am feeling "bumpsteer" from the rear, and I have suspect worn out upper bushings. Do you sell the uppers only as a set of 2? I would buy them from Ebay."
Thanks in advance,
John , VT
We set the standard AS the FIRST Cadillac Replacement Bushings on the market! We have PAT PENDING on our products for a reason!! All the rest are cheap imitations so why would you want to pay twice ??
Customer responses: see our "feedback" section from customers)
"I can't tell you how thrilled I am to have these bushings available. I had them installed and what a difference in the handling and ride on my Deville. Your excellent customer service, and going the extra mile is refreshing in todays business world.
Thank you!"
DAVE , Iowa
Hello, I just wanted to say how grateful I am to your company... as those lovely folks over at Caddie don't carry them as a replacement part…… Your help when I needed it via phone was immediate and accurate. You set the bar for outstanding customer service. These are tough times and most of us are tightening our spending…….I will recommend your product to any and all caddie owners with the same very common problem.
Thanks again,
Mike , IL
