99 deville..with ac on auto the airflow switches back n forth from ac vents to defrost..would that be a..programmer issue
(I think the partial vacuum setup was still used in the 1999s......)
Check the vacuum line from the passenger end of the intake manifold to the firewall and into the cabin/HVAC stack.
Does your parking brake auto release work? If not, it's a vacuum leak somewhere.
park release works...also vac source is good..can find no leaks...while driving it will just switch to defrost..and later go back to ac vents..so i am thinkin what tells it to switch..back n forth..with out commands from ac control head?
you - the MODE is vacuum controlled -
and when you loose vacuum DEFROST is the default position -
long hard acceleration dumps vacuum -
coasting/deceleration develops the highest vacuum -
yes i get that..just sitting in park it will do it...gonna check the vac res..under the fender..so far i found no vac prob...till tomoro...thanx much
