OK - I have a fuel pressure problem with my 99 Deville. After sitting overnight or more than 12 hours all my fuel pressure bleeds off the rail. I have to turn the key off and on about 6-8 times to cycle the pump and get it started. I've ordered a fuel pressure tester but haven't got it yet. This morning before I cranked it I checked the schrader valve and not a drop of fuel came out when I pressed it in. Once I got vehicle started I pressed it again and had fuel spray out like it should. I've already replaced the fuel pump and the FPR and no luck. I can't smell any fuel when running or not. I'm leaning towards replacing the injector O-rings next. Has anyone had similar problems? The car runs and cranks perfectly after the initial morning start. Any suggestions would be appreciated.
Also I got a Fram G7315 fuel filter that is supposed to be for the 99 Deville but the threaded side is too big - what's the deal with that?
Oh - and there are no codes being triggered either.
