1 - 8 of 8 Posts
2006 STS V8 1SF RWD
Re: No start 98 sts
1st off, you're in the wrong forum, you need to go to the Seville forum, not the STS. Sounds to me that if fiddling with the shifter improves things you have an intermittent failure of the neutral safety switch that gets worse with heat. You'll have better luck in the Seville forum though, heck, a mod might even move this post over there for you eventually.
Reactions: nate6966
· Administrator
Re: No start 98 sts
So you turn the key to START and it rolls over and over for some period of time but will not catch, run, idle ?
Or, you turn the key and nothing happens (as in: no crank)?
1 - 8 of 8 Posts
