Hi Guys,
Just want to put you on the lookout for a problem with late model Northstars. I was told by my dealer they see a lot of this problem, and there's a technical service bulletin out there on it.
The cylinder head bolts are stripped in the engine block bolt holes. This is either over-tightening at the factory or just a defective design. The steel bolts are threaded directly into the aluminum block.
GM has a "special program" for paying for 50% of the repair IF your car is under 70K miles (mine has 80k).
I was alerted to this problem by a "low coolant" indicator on the DIC. I added 2Q of coolant and made a mental note to bring it into the dealer.
The retail repair bill is $3800! The president of the dealership is a friend, so I'm getting an $800 discount.
Needless to say, I'm contesting the repair with Cadillac, and I'll be suing in small claims (or not so small claims) court to get the repair paid for.
I also have the dreaded half case oil seepage, but the additional cost of getting that sealed up was $1280, so I skipped it.
If any of you can point me to information (online or other places) providing more information about the cylinder head bolt hole stripping problem, it will be much appreciated!
Thanks,
Dave
Edit by Sal: Just to let you know, Dave - HTML code doesn't work here - BUT - vB code isn't much different. Instead of using a greater than or less than sign - use a straight bracket to open and/or close.
Thanks,
Dave
