98 Devil, 93 Deville, 84 Cuttylac built 350 olds, Arctic Cat
Ok, I know there is a ton of literature around but I have been sifting through it and have not found a straight forward answer to my question.
The rear end of the car wasn't absorbing bumps like it should, It does now but, still leaks air and sometimes gives me a rough ride. I recently bought two arnott shocks and upon installing the shocks and pulling hte air line they released air.
Now the problem is though, I have a really slow leak, Most of the time That I park the Car after a couple of hours the air ride system will release the built up pressure and the air pump works almost everytime I go to start the car in the morning. I know this could be the lines, i think I've read about the air dryer and something else but I would feel a lot more comforitable if you guys could help me out on my situation specifically, If I have to pull the air pump so be it I have 4 6-Ton Jack Stands and a 4x4 block of wood.
Where Should I start and What should I Do? Also My pump has probably been running 85% more than the average persons pump for about a year so is there anything I should do to maybe rebuilt, lube, change oil or anything to freshen it up. Ive read something about getting a new air dryer.
Thanks much,
Brian
Thanks much,
Brian
