I have a 98 Deville Concours 211,000 miles. Back in June 2012 after driving around all day in stop and go traffic RPM's started running very high and the car was pulling without me using the gas. I had to stand on the brakes to get it to stand still. Pulled off and let it cool down a little while. Back then we added coolant or oil which turned out to be low and now we can't remember which one it was!
Over the weekend before and through Christmas Day I have put a little over 800 miles on the car. Some open road and some stop and go traffic driving. Monday evening the high RPM issue came back strong. Pulled into a gas station and added coolant oil and transmission fluid. All looked a little low. Got home fine however the Service Engine Soon light is on in the dash. Now it keeps doing it almost every time I start it.
When I start the car if it running high RPM's I shut it off and restart. Sometimes the RPM's will run normal after the first time but sometimes I have to turn it off and on several times before it does it. Sometimes the car runs normal the whole trip and sometimes the high RPM situation develops while I am driving.
We are losing coolant but can't find where. We are suspecting the hard cross over pipes at the back of the engine and have done this repair on another 98 Deville so we know what to do - just holding off because we aren't SURE - we can't SEE the coolant leaking from that area as we did with the other car so it's not certain that is the issue. Replaced the heater core earlier this year and just last month the upper and lower radiator hoses. No apparent leaks in the radiator so we haven't gone that route just yet. I am thinking I need to get a shop to pressure test but this worries me because I am fearful they will blow something out doing the test leaving me with no car to drive as my husband is in the middle of a major front end rebuild on our 2nd vehicle.
We are also losing oil - not a LOT and cannot pinpoint the source of that leak either. We keep close eyes on levels of both so there has never been a time when they ran low or out.
When I get stuck in really bad traffic that is stand still for a period of time, roll ahead a few feet, stand still again .... after a while of that the car starts running very poorly. I try to avoid this type of traffic to the point of just pulling over and waiting it out for a little while if I can.
I will pull the codes tonight and update this post with what it is reading but just wanted to throw this out to get your input (as I value it highly). Possible Throttle Position Sensor issue, EGR Valve, etc.?
This year we have replaced plugs and wires, alternator, new battery, blower motor and heater core. I get the oil changed with high mileage synthetic blend religiously. Nothing but premium gas either.
We do all of our own work despite my husband's complaints. Our bank book can't afford it and I really would prefer to KNOW what was done to my car rather then spend a lot of money and not be sure who did the work.
Can anyone provide any input at this point? Thanks!
