1 - 9 of 9 Posts
DeVille
This noise doesn’t seem to be associated with the operation of the car. The car is in good operational condition. One mechanic said it was the heating/AC system. That something was malfunctioning, kinda stuck trying to open but not quite and keep trying. The noise is very much like a turn signal noise. Anyone have any experience with something like this?
STEP #1 - ALWAYS - check for DTC's - Diagnostic Trouble Codes -
if you don't know how - go here -
post any codes you have -
ALONG WITH THEIR DEFINITIONS -
include whether they are C-Current or H-History -
for code definitions - go here -
I suspect the sound is coming from the climate control system -
your 98 Deville uses vacuum to control the MODE - where the air blows from -
and electric actuators to control TEMPERATURE -
change the cabin temp - see if the noise changes -
I agree with Bass. Most likely a stripped gear tooth on one of the actuators.
deville 98
The clicking is in the actuator behind the glove box. Takes about 30 minutes to swap. Did mine about 4 months ago in my 98. You probably don't know it, but your a/c will blow warm on the passenger side because of this. Part will cost approx. $20-$40 depending where you get it from. Just take apart your glove box and then pretty sure it's just 3 screws and a plug, but in a tight space, to change actuator, which takes time.
utube is your friend. Search for - replacing actuator behind glove box on cadillac...... there are a couple of videos.
Good luck.
........... or Google "cadillac forums 1998 deville hvac door actuators" or something close.
DeVille
Good luck.
Thanks I’ll search YouTube for your suggested video
DeVille
Discussion Starter #8
Thanks for your help. I can’t do the repair myself but I’ll take your suggestion to my mechanic, at least I’ll have a idea of cost.
FWIW my 92 Deville and 94 Park Ave used to click behind the glove box when the battery was very weak. The cars would usually still start but that was my warning to charge the battery. My cars sometimes sit for a couple weeks at a time.
1 - 9 of 9 Posts
