Sorry that the first post is so general. I've been searching on what to do and I forgot to mention the situation. While driving on the highway, the message "anti theft system... car may not restart." The traction control light came on on the dash. When I shut the car off, it started back up no problem. I drove the car around town a bit, still no problem, it was as if the system reset itself. Once I got back on the highway and drove for over an hour, the anti theft system and traction light came on again. This time though, all the lights on the dash went crazy! The fuel, mph, rpm, everything except for the total miles of the car. Once I returned home and shut the car off, I started it right back up and again, everything back to normal. I noticed that the volts had dipped down to 12.5, usually its at 14 something volts. Finally, I was driving thru town and 2 minutes from when I started it up, anti theft system and traction and crazy lights came back. I noticed a little roughness in the idle, 575rpms, so I figured I should get the car to a place where I can work on it incase it really doesn't restart. Good thing, the car doesn't even budge. There is a small running motor noise that comes from the engine, very faint.
I've tried disconnecting the battery and trying a different key... no success.
Again, any help is APPRECIATED!!
Thanks for you help in advance!
Carl
Carl
