My 98 deville apparently has a slow leak in the compressor from what the shop told me. they want to charge me 1000 to fix. So I'm wondering what exact model or part# I need for a new a/c compressor. Also any advice on an easier install. Should I rebuild or buy new/ diy or shop mechanic/ and a few instructions on how to replace. Any help is appreciated I think I possibly found a replacement for like 250.00. THanks much!!!!:thumbsup:
97 Deville
Hey tracy you might want to recharge the system a bit and put a colored A/C dye in it to see if the leak might be in more than one location. I have a 97 Deville and they told me the same thing oh you have a leak in your A/C system you need to have it replace and they qouted me $1050 i didn't really trust them so i took it to another shop and they recharged it and my a/c worked fine for about a month but since i had them put some green dye in the system i found my leak. So i would try that before you go and spend $1000 and then drive 10 miles and you have the same problem because there have been a few people in here who have done it.
Good Luck
2010 DTS
If you have to replace it, I'd go with a new A/C Delco. From what I have read I would stay away from aftermarkets and rebuilds. It is a bit of a job if you are going to DIY. Much depends on your skill level. After it is done you'll need to have it vacuumed down and recharged.
Cadillac Deville 1990
Tracy,
I agree with pnj2108 take it to another shop and get a second opinion. To bad you don't live in Houston or I could have directed you to a place to take it.
they did run the dye through it and said it was the compressor. from what they said it was by the front wheel well where the compressor is. should i take it to a Cadillac place or do you think they will hose me. cause they want like 100 bucks just to look at it. it sux being in florida and not having ac!!
Texas and no A/C is not a picnic either...lol I would still take it to someone else for a second opinion plus it gives you time to search for prices. You don't have to take it to a dealer for this.
