1 - 11 of 11 Posts
'98 Catera
My 98 Catera needs a vent valve (part number 90541907) to pass the emissions test. I have called part stores, dealerships, official GM parts distributors and no one can find one. Is anyone parting out a Catera or know of a salvage yard that would likely have one? I'm open to just about any solution.
1999 Catera Sport
Try car-parts.com. Do a search for something generic like a hood, fender, etc, to find a local yard that at least has a catera, then call them and see if you can work something out. :cool:
Catera
There is a yard near me that just got a Catera in on Friday, so I am going to go check it out tomorrow. I'm not too sure what part you're talking about exactly, but if you could let me know I will grab it for you.
'98 Catera
I can't post links or pm right now because I'm a new member but if you go to
"gmpartsgiant[d]comcomponents1998-cadillac-catera~fuel-supply-fuel-lines-ov030020103-l81ml46vr69[d]html"
[d]= .
Stupid spam blocker.
It's number 42 on the diagram. On the car, its located in the top left corner under the hood. It should be pretty easy to remove.
'98 Catera
Mechanic just called. He said it might just be a sensor. He's going to check it out. I might not need the part after all! Thanks for grabbing it though. I'll let you know if I need it or not!
L
Guest
please let me know what sensor he replaced im having that evap problem as well thanks.
2000 Catera Sport
If u have evap small leak code. There is return pipe goes in to gas tank from electronic vavle in the front of gas tank. That pipe was cracked, I have to take tank down to replace it.
2000 Catera Sport
1 - 11 of 11 Posts
