1 - 20 of 41 Posts
The Northstar Tuner
I want to break this up to preserve my brain. LOL
smooththg6969---- 99 SLS
axe--------------- 99 STS EU
mrnuke7571------- 98 SLS
mike0580a---------99 SLS
awdblackteam----- 98 STS
CASTOR TROY----- 99 STS
tripledoil-----------99 STS
The Northstar Tuner
Discussion Starter #2
Originally Posted by CASTOR TROY
if i get mine by this weekend ill take em to the track in lowellville pa its $2 a run ill do a bunch of runs with and w/o aj,s pcm see what i come up with!
weather permitting! not a dyno but it may have some positive results.
CASTOR TROY has #1
I have done a few for myself, but he has #1 and #2.
#2 did not start, :mad: But that was why I sent 2.
I only have my 99 VIN Y Powered Fiero to play with. I needed a VIN 9 to try a different program.
We will have some result on this in a week or so. True numbers from the track
The Northstar Tuner
CASTOR TROY
I am at a loss. I thought it was because of K29 RPO. I am running a K29 in my Fiero. The PCM I sent that did not start. Does it have a white sticker on it? I would like to know the 4 letters on it. example: CHTS, CPYK, CABY.
The Northstar Tuner
GOT MY PCM,S!!!
aj you have exceeded my expectations i can feel the added power... on the way to work 2day broke over 130 i let off at about 142mph she had more tho... AJ YOU THE MAN YOU THE F-IN MAN!
moved
Would this thread include '98 Aurora?
I bought a ECU from ebay that's from a '99 Aurora; says it fits 96-99 Aurrora, 96 Deville, 97-99 Deville, 96-99 Seville, and 96-99 Eldo
Tag on unit:
SERV.NO. 16214848 CPYD
The Northstar Tuner
Tag on unit:
I am taking a step back and just doing the 00+ and 98 and 99 Seville's.
The one 96 eldo ate too much of my time. I am going to personally install it this weekend.
You stated that you want to do many mods to your car. I think after you get it all done I should work on a program. You talked about injector changes, T-body. I think that after you are done I should run the #s for the different injectors.
The Northstar Tuner
:lildevil::bump:
The Northstar Tuner
Discussion Starter #9
so Aj what do I need to get you started programming my Pcm I pmed you but got no response.
I need a PCM #16214848
I am running short on them. I had some, but killed two, sent two out (NO PAY & NO RETURN ON THE SECOND ONE). I have two currently, but they are spoken for. The last two I purchased ran $50 each.
This PCM fits 96 to 99 Northstar's and Old's Aurora :bouncy:
99 Seville SLS( parts) ,98 sts
ok Aj I just bought one out of a 99 Deville it should be here next week. do you want to pm me your address so I can get it shipped out as soon as it gets here? also is there any way you can get rid of the Pcm420 code I get every now and then ? I know why its there I have a high flow cat and magnaflow mufflers or am I gonna have to get the o2 sim thanks
98 STS
Please add me to the list I have a 1998 STS
vin 1G6KY5499WU903033
I'm guessing I need to get a PCM 1621484
Please PM with your contact info and cost
Craig
The Northstar Tuner
Discussion Starter #12
I am working on some new programs. The ones done are great. The next step are going to be a PCM that I would not suggest running for more than a few hours at a time. It will foul the plugs out, but it makes loads of power.
The Northstar Tuner
Discussion Starter #14
I am working on the Po420
AJ can you PM me pricing on this and whats involved?
I will PM you later. I am going out after work so it maybe late
Cadillac 98sls
aj please pm me about speed limiter I have a 98sls with s speed limit 112 mph what do you need Iwill provide it to you whatever it is please thank you. coaster
The Northstar Tuner
Discussion Starter #18
hey Aj I went a bought a total of 3 pcms for 96-99 programming I have them in front of me. can you pm me your address so I can get them shipped to you. also what programming options do i have for my 99 seville sls
They made it here
The Northstar Tuner
Discussion Starter #20
It is all done. I am working on a P0420 removal for the second PCM:sneaky:
I have a 00 to 03 with all the emissions removed from it, so I know I can do it.
1 - 20 of 41 Posts
