!979 Eldo Sloppy Gear lever
504 Views 2 Replies 2 Participants Last post by  BIRD-60
Hi Guys, I have quiet a lot of play with my Gear Lever. The other day the Eldo started in gear, is there an adjustment.?
Thank You
Chris....From OZ
Get under the car and locate the shift rod that attaches to the lever on the transmission. The rod should have a bushing around it to fit tightly on the lever. Most fall off over the years leaving wasted motion in that rod. I've used a door hinge bushing kit sold by AutoZone for older Chevy trucks. It has an assortment of brass bushings. One will work, then I use a thin wave washer as well. That rod is adjustable just below the brake booster. A cross shaft comes from the exhaust manifold over to the frame. That rod is held in place by a nut at its upper end. Loosen nut, gently slide the rod into position.
Thank you for the information Carnut, & your prompt response.
Chris....From OZ.
