97 STS - Rear Coils R&R
772 Views 3 Replies 2 Participants Last post by  Closet Boy
Any advice on replacing the rear coils would be greatly appreciated.
Holy crap! Just finished replacing the rear stock coils for lowering coils. Man, lotta grunt work. In the battle, I used one can of WD40 and lost a coil compressor(rental, I own it now).
Using a standard issue spring compressor was tough. The coils are small compared to what I have experienced in the past. Not much room to manuever within the coil. Also, the compressor bolt was way too long. I ended up cutting off a portion with the good ole angle grinder.
Man, it was tough...
I assume you are lowering the front too? Did you happen to take before and after photos?
-jadz
Yes, I installed the FE1 struts. No need for before pics. The difference is huge. I will post pics next week. It is still a WIP.
Have the power resistors to install today. I wired them up to the old harness. Used connectors and silicone to waterproof.
Will keep you posted on status.
