I currenly have GYEagle RS-As that are almost completely worn out (55000miles)
Could anyone recommened replacement tires?
I've looked at possible ones:
Goodyear RS-A, Regatta 2
Michelin Hydroedge, Harmony
I've heard bad things about RS-As...so I maybe want to replace them, although I've never had any major driving problems with them, but I never owned any other tires before, so I can't make a comparison.
I'm looking for All-Seasons High Performace OR All-Seasons Premium tire that has good control, stability, cornering and dry/wet traction...and moderate winter capabilites.
Thnx for help.
1998 Cadillac STS
I picked up a set of four Bridgestone Turanzas for my 98 STS in Nov and have been completely satisfied. They are excellent in wet weather. I go through standing water like it's dry pavement. I got 'em for $116 a piece at Firestone (mounted, balanced, warranty, and lifetime balance). Not too bad.
'98 STS (RIP @ 206,xxx miles)
Speed rating is going to reduce the number of brands/styles you have to choose from. Tire makers do not produce tires to "H" or "Z" speed rating specifications in every tire style. Your car most likely came with either H or Z. Check the factory sticker; mine is on the driver's door.
You might even find a tire dealer who will refuse to install a speed rating lower than the original equipment sticker.
I am happy with the wet/dry performance of my Michelin MXV4 Plus set. Good luck.
1996 Cadillac Fleetwood Brougham
I recommend you to use Bf Goodrich or Michelin and never leave original size so stick to it My choice is 235 /60 16 Z 100W
Hope you will be satisfied with the tryres :)
05 SRX (past- 01STS,93STS)
I just put Michelin Pilot A/S on my wife's '93 and they seem to perform well, particularly in the snow.
Check out the TireRack.com under ultra high performance all season. They have ratings there too for what that's worth.
Mike
