The car I'm looking at is a 97 STS, 111K, $3K. Car was in this shop for head gasket job; they sent block/heads out for repair ($800 !), then they gave car back to owner. Owner drove it for 2 weeks, then had it towed in with 'no power' complaint. Since owner had not and could not pay for first repairs, service shop became owner. They're selling to recoup their $$.
So I looked at car and it's great in/out. Engine ran, real rough at first, no response to acc pedal at all. Sounded like exhaust manifold leak, misfires. Had to start it 3-4 times (trying to warm it up for compression test). I was able to rev up a bit, and engine ran a lot smoother, very little smoke at pipes, still heard what sounded like exh leak. No big knocks frmo bottom (good news, I hope).
I did a comp test; found ~210 PSI (120 on first stroke) on the right (rear) bank, and 180,170,180,160 PSI (90 on first stroke) on the left (front) bank. When I tested the front 4, there was a 'pop' noise during each turn of the engine. But when I tested the rear 4 (all ~210PSI), there was no pop.
So, I think the front head is loose (or big time gasket malfunction) since all 4 cylinders read low and each cylinder produces the pop sound during compression testing. I have to wait until Monday to learn exactly what the machine shop did (helicoils? Timeserts? All holes, or just some holes, etc.).
My first question is: Can I get a shop to timesert the left (front) bank while it's in the car? Or is that a foolish thought? (I'll look for a different shop, unless the first wants to do it for free and I can find someone who can vouch for this shop's expertise in N*.)
2nd question. Assuming I pull the engine, what do I do with the right (rear) head. Leave it on? If I have to take it off, should I get those holes timeserted if they weren't done before? I know other threads suggest doing all holes if you're doing one, but the head is working great as is.
Your replies are much appreciated.
