1 - 2 of 2 Posts
I was just wondering, I havent done it for a while but, If i really get on the gas...floor it that is. The check engine light comes on but then turns off after I start the car a few times. Any guess to what that is? Car has 120K Kms on it.
94 Eldorado, and a 99 ETC
Check the codes to find out.
Press and hold the OFF and passenger warmer buttons at the same time untill the dashboard lights up and it should start telling you the codes. Write them down and post them here and someone will help you. When it gets to "PCM?" you can simply turn the car off to exit diagnostics mode.
1 - 2 of 2 Posts
