97 Deville
I just had timing issue fixed on 97N*, it was out 180 degrees from where it was supposed to be. $2300.00 later seems to run fine. Drove from Ozark, MO. to Indianapolis, IN. Ran fine for the trip up but did throw the following code on arrival:
P1441
P0741
EVAP during non purge and I am not 100% sure on the 741.
Cleared codes and drove around Indy with no problems.
Drive back home it threw the same codes when I got home.
Any suggestions?
It also has what feels like a small miss when I am in idle and in gear.
I notice nothing on take off except maybe a slight hesitation.
No codes come up during this.
P1441
P0741
Any suggestions?
P0741-
this is caused by a worn seal deep in the trans -
around $2500 to repair -
if you are NOT in an area with inspections/emissions testing -
you can "live" with the code - forever -
you will loose a couple/few MPG at highway speeds -
for a complete explanation - including pics - go here -
http://www.cadillacforums.com/forum...on/149834-information-p0741-p1860-1998-a.html
2010 DTS
Always include the code definitions along with the codes. We don't have them all memorized yet.
