Hi all. I've got my eldorado overheat problem 90% solved, found a clogged line - replaced, radiator and heater core - replaced, thermostat - replaced, cracked reservoir/overflow tank - replaced, block test comes back negative for head gasket issue, but she's still overheating at stoplights/in traffic. But when she gets moving, even coasting she cools down which makes me think its possibly the fans in front of the radiator. Should they start spinning as soon as i start the car, or is there some kind of condition that makes them go on/go off? Is it common for the fans to go, or is there some kind of relay or electrical component i should look at before plunking down $130 on new fans? Any advice would be appreciated.
